RCU Forums - View Single Post - Plettenberg maintenance?
Old 09-03-2011 | 04:33 AM
wagen017
Default RE: Plettenberg maintenance?
now the motor is really difficult to rotate by hand. I know if I power it up it will loosen a bit (temperature) but does not seem safe to fly anymore.
There must be more bearing failures. 500 flights is not that much.
Are you able to replace the bearing easily yourself? Do you need any special measures to do it? Better to send it to Plettenberg?
Would appreciate some advice here!
thanks.
Volkert
