RCU Forums - View Single Post - E-flite Super Cub 25e ARF
Old 09-05-2011 | 10:36 AM
skorman
Default RE: E-flite Super Cub 25e ARF
I just maidened my Super Cub and it went very well. Easy straight take off. The Power 32 is a perfect match for this plane. Differential is definitely needed for smooth turns. The manual explains how much to set. This cub, as most do, tends to float in on landing. Set it down on the mains and let it roll out. The tail wheel with its very weak springs leaves a lot to be desired and ground handling is not very good especially in any wind. I plan on replacing mine with a Sullivan tail wheel assembly. That is, IMO, the only problem with this ARF. Cockpit kit looks great and is worth the extra time to install. The lights on the other hand, while pretty cool, aren't the easiest install and are hard to see in daylight. The finished plane is a beauty and attracts a lot of attention at the field. If you like scale cubs, this one is a keeper.
