RCU Forums - View Single Post - Smoke system injector at tail???
Thread
09-06-2011 | 05:19 AM
14
Jetpilot24
My Feedback: (
21
Jan 2003
1,500
Niles, OH
RE: Smoke system injector at tail???
Mark if you use a 3/16th inch tube between the walls the fit is tight enough to secure it. you can also use a piece of glow fuel blue fuel line around the outside of the tube and wedge it between the pipe at the back. it will stand up to the heat. I also use a one way check valve. I found that the pressure from the tail pipe will actually cause the smoke pump to lose its prim in flight. I also set up a header tank so I don't get the negative G on and off smoke through maneuvers.
Joe L.
Reply
Like
Jetpilot24
View Public Profile
Send a private message to Jetpilot24
Find More Posts by Jetpilot24
View iTrader Profile
