RE: Best 100 - 120cc engine for 3D
TOM
Why does cannisters make the 120 a good choice? Everything I've read about cans in this Forum and in others is the only real benefit is the noise reduction but with a little added weight and no gain in power. I guess I'm concerned about weight because I fly mostly 3D (or at least try to). I figured if I can use a lighter engine that will produce a sufficiant power to weight ratio then it won't be nessesary to use a heavier but stronger motor like the EVO. You do make a valid point about BME. I am still considering that motor.
