Dunno about the 'thrill of my life' bit - Bali must have cum close
But I sure hope you get to appreciate the 'Bear for what it is.
It's not exactly a World Record beater, that's for sure. But then again, it's not costing you an arm and a leg.
IMHO, be patient with it. Dial yourself and the plane into what it can do.
For a lil foamie running on 3S 1000mAh, it
can shunt along at quite a lick.
Be warned - it's deceptively fast. You'll find that out for yourself first time you stove it into the ground at around 90mph [X(]
You should be able to see my 'hi-viz' duco job here:
http://www.rcgroups.com/forums/showt...6#post19063937
BJ
PS - black bars on the underwings. You can't possibly screw your orientation perspective with that - and it looks real WWII that way
