Since you have the 8FG, you can set your transmitter to the correct wing and tail style.
Just go into Model Type and select 2AIL+2FLP for the wing and AILEVATOR for the tail type. Then check your servo screen, you should see that ailerons are 1 and 6 and dual elevators are 2 and 5.
From there, just set AFR and rates up on each channel and you should have what you are looking for.
If you are wanting to mix some Elevator into your Ailerons, you can then go to the Model menu and go into CMBFLP>ELE menu.
Should you have any further questions or concerns, please do not hesitate to contact us at this email address. Please be sure to copy all previous emails into any future questions. You can also reach our product support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
