Flyingagain, I am wondering if the water based polycrylic made by Minwax would do the trick? I have used it many times, but never to actually adhear the covering down. Im thinking a few coats around the parimeter, let dry, apply your covering and go back over just the edges again and let dry. Sort of like when useing silkspan. I'd try it on a test panel, but its definately house friendly. Be carefull not to soak the wood too much & cause warps, since you wont be sealing the wood first. I'l be anxious to know if this works for you...Good luck....Gene
