I like to use standard size servo horns because they hold pretty good,provide a clean looking mount and make it easy to remove the body when you want because the surface is smaller. I simply grind out the center of the wheel, drill a small hole in the shoulder to hold the body clip, shave the top flat, and cover with Velcro
