RCU Forums - View Single Post - Second Plane - H9 Pulse 125 XT?
Old 09-14-2011 | 11:32 AM
scooterinvegas's Avatar
scooterinvegas
Default RE: Second Plane - H9 Pulse 125 XT?
ORIGINAL: Gray Beard
Perfect plane and both the DLE and Zinoah are perfect for it. Gas is easier then glow.
+1
I have a Pulse 125, its a great plane. Its more of a low wing trainer, very easy to fly and land. DLE-20 is perfect. Put a 17x6 on it and change the stopper on the stock fuel tank. Reinforce the landing block with some tri-stock/epoxy, and tape the elevator. The Pulse 125 builds tail heavy, so the DLE-20 works well for CG. Some run two push rods back to the elevator (one for each side) because if you over speed the plane in a dive, the elevator has been known to come off the first gen 125. Horizon beefed up the elevator rod on the newer ones to prevent this from happening.
But other than that, its a great plane. I love mine.
