ORIGINAL: electricpete
i am also interested in a 4 motor set up (Lancaster)using with a spektrum dx8 . i am considering using two reciver Is it possible with ar 6200. I would be happy to control inners with one RX and outers with 2nd RX.
Peter
As long as you Bind each receiver, one after the other, you should have no problem with using Redundant receivers. You will still only have 6 channels to work with. I don't think it matters which receivers you use. Most people do this for Redundancy, or because it makes it easier to assemble a complicated aircraft when you can put one receiver in the fuse and one receiver in the wing, for example. Mixing the Throttles on four motors requires the use of Programmable Mixers unless there is a Canned Program in the Tx that handles this.
