RCU Forums - View Single Post - Setup for multi engine
Old 09-16-2011 | 02:28 AM
ntsmith
From: Bishop\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'s Stortford,
Default RE: Setup for multi engine
Sounds interesting and very possible. One thing I found really interesting was the "My normal procedure on an electric is to first inhibit the throttle trim. I set this up so there is no trim on all the motor channels." I have never done this. Presumably this would then give the full throw over the channel. What advantages are there in doing this? I have found that with trim and memory on it is very usefull. One click on the trim and the motor is idleing. Could and would this be able to work with your set up. EG one click to the trim and the always fucntioning motor 1 (rear motor) is running then trim on motor two and the rear left is ideling and trim 3 to start all three motors goind. It certainly would look good
