RCU Forums - View Single Post - Setup for multi engine
Old 09-16-2011 | 09:02 PM
AWorrest
Default RE: Setup for multi engine
Nigel,</p>
What I outlined is one of a couple ways to implement multi-motor control. I’ve been playing with using the WING TYPE’s TWIN E function but getting three motors to come on-line in the sequence as your wish is uncertain. However, if you are building a twin engine model, I would definitely recommend you use the TWIN E function instead of the program mixes I used. I was pleasantly surprise to find the 11X has separate THRO HOLD for each engine. Using this function would make the programming cleaner.</p>
Allan</p>
