RCU Forums - View Single Post - 3D Zap settings
Thread: 3D Zap settings
Old 08-20-2003 | 01:42 PM
schroedm's Avatar
schroedm
Default 3D Zap settings
Hey Greg,
As you know I have the Zap WCII as well. Am sitting at work so this is from memory.
Keep the ailerons plugged channels in 1 and 6, activate the E>F mix and assign the "ON" position to the centre position of a 3 way switch. The bottom position is E>F mix off i.e. your 1st point and now the centre is E>F on i.e your 3rd point.
Next set up a "flight condition" that uses the E>F mix with the +/- setting opposite to your std elvator to flap mix so the ailerons go up with up elevator. Assign this condition to the top position of the 3 way switch and voila, the three settings on the one switch.
See you up the field soon?!
Regards,
Mark
