3D Zap settings
Vease,
Just got meself a WC2 as well. I too had problems programming it to the point I almost through the thing across the flying field.
Finally got to grips with it after getting me mate to show me what to do.
You want to set up everything on 1 condition to start with, all your mixes, subtrims, blah blah blah. Then copy the condition you've just set up and go into that one and modify it, ie: reduce control throws, change mixes, etc, etc!!!
Its alot easier to modify a copied condition than it is to create an identical from scratch.
The thing I've noticed with the ZAP is that theres about eleventy million different ways to do one thing!!
If your going to the Nats display thing this weekend come giz a shout and I'll try and sort you out!!
Phil
