RCU Forums - View Single Post - ASP 108 gonna be the death of me
Old 09-19-2011 | 11:21 AM
hsukaria
Default RE: ASP 108 gonna be the death of me
I've had engines go suddenly bad, it was dirt in the carb. Try pumping fuel through the carb at idle and WOT to flush it out. It helped me.
I have a Magnum 52 4-stroke (same as ASP) and I just about gave up on it. I have almost 2 gallons of fuel through it and I have concluded that it is an easy starter, but idle stays too high unless I lean out the LS needle and reduce WOT power. In the end, it will be a basic low power engine. Easy to start, but weak.
The money I saved in the price of the engine, I spent on the extra fuel to break it in (+aggravation). Just run it on the bench with old fuel to break it in (2-gallons from the concensus here).
