RCU Forums - View Single Post - trex 600 e esc issue
Old 09-22-2011 | 12:15 PM
jnail
Default RE: trex 600 e esc issue
If programming the esc doesn't help, you will have to go into your travel adjust menu an the dx7 and set the bottom end of the throttle into the negative. My friend has an align esc on his trex450 with dx7, and we had to set the low end of the throttle at -109%.
You could also try re-binding the RX. I am told that sometimes this solves wierd throttle problems
