RCU Forums - View Single Post - Hobby Lobby Telesport build
Old 09-23-2011 | 02:09 AM
tonywayne's Avatar
tonywayne
Default RE: Hobby Lobby Telesport build
Starting to look like an airplane. Framing the wing up is what i dreaded most and so far nothing has tested my patients, it has been a joy. Only a few slots in the ribs needed to be re sized for the spars to fit in. The tabs on the bottom trailing edge of the ribs for support were cut accurately for the wing to sit level. I do not trust the two 1/16" ply pieces for the dihedral braces, i will be adding more braces or glassing the root. I have to remind myself to make holes in the ribs for the aileron harnesses as i will be installing two servos one for each aileron. All the ribs and spars are strait and square and i cant see any warp at this point. Maybe this weekend i will have enough time to at least have the left wing complete, maybe both.
ID:	1665567   Click image for larger version
