RCU Forums - View Single Post - Delro ADDICTION
Old 09-23-2011 | 11:36 AM
  #71
Jon Wold's Avatar
Jon Wold
Default RE: Delro ADDICTION
ORIGINAL: ELIAS SOPEOGLOU
Jon ,if you mean that a warped wing acts the same way as the heavyer tip inverted,I have to dissagree as a warped wing will roll the same way right or left either straight or inverted.Unless I missundertood your statement..
Elias
Sorry I wrote before thinking (again!) I meant not warped, but if you have adjustable incidence on the wings and the incidence is slightly different, when you trim this out for normal flight that trim becomes inverse when flying inverted. This can be measured of course, a difference in wing weight is more likely.
