RE: Geared to Direct Drive
The motor will try to turn at it's KV rating. If the prop is "smaller", more than likely it will approach that RPM point better than a larger one. It won't exceed that RPM if that's what concerns you.
If the motor bolts on and the gears match, I can't see any downside to it.
CGr.
