RCU Forums - View Single Post - Programming a 3Way Switch on SD-10G
Old 09-25-2011 | 09:40 PM
paulGT3
Default RE: Programming a 3Way Switch on SD-10G
Here is something else I have done that has got me close. IN Aero mode I found out Channel 5 is the gear, so I played with that switch and I got Two of the modes from my quad copter
unfortunately they are the Return to home and the Altitude hold mode. No mode for just flying around. Then I moved the plug to channel 6 which had the FLAPS AND the Flap Trim switch VR6. That got me stabilzed fligth and return to home but no THIRD mode. I am getting close as soon as I find a three way that lets me adjust the values more than the trim switch I should be able to get all three modes!!! I am close and I can smell it!!!
Again thank in advance.
