RE: Hawksky not flying
In addition:
- The ESC may have not "learned" the full range of the transmitters throttle. You may have to "teach" it the full range again.
- Check to see that the motor and prop turn freely, the motor should not heat up when you run it full throttle for a few minutes.
- Please provide the URL for the replacement battery pack you purchased.
- Most ohm meters are useless to tell you the state of the battery pack.
- The 400 brushless motor and ESC provided is normally a very good match to the plane, so something is amiss.
