Carl, you told me you couldn't understand why I sold it as it was so good
Time for something new?
I'm toying with the idea of a BARF MkII but not sure I can justify the expense and can't see it being as good as the Flash anyway.
One other tip for the Flash.....when pushing in the canopy retaining rod make sure that it does actually engage with the canopy. It is quite easy for the rod to lift the canopy a couple of mm and sit underneath the rim. If this happens then the canopy can come off in flight.
