RCU Forums - View Single Post - Comp ARF Flash Hints / Tips
Old 09-29-2011 | 05:35 PM
Wayne22's Avatar
Wayne22
Default RE: Comp ARF Flash Hints / Tips
Put as much stuff as far forward as you can to avoid needless added weight of ballast. (I moved the UAT over top of the nose gear, as an example. ) First one has a P-80SE and it is pretty zippy (as opposed to ballistic) even at half throttle. You SS should be fine, as long as you watch the weight.
