RCU Forums - View Single Post - Phoenix Spitfire 40 ARF
Old 10-01-2011 | 05:46 AM
  #58
darylk79
Default RE: Phoenix Spitfire 40 ARF
Just a note: A 46fx motor with a 3 blade 10x7 master airscrew is plenty power for this plane.I suggest you add half the weight needed to the nose when balancing because the manual cg is off.85mm from the leading edge is to much and makes the plane very nose heavy.I will rebuild one last time and report my finds in about a week or two.
   "Good Luck and God Speed"............And try not to die!
