G'day spitfire66,
just checked your radio manual spitfire66 JRsx600 and it tells nothing about mixing aux flap channels..only mixing for delta wing etc..
Unfortunately I don't think you will be able to have down elevator trim mixed in when flaps are deployed using that radio.....You are going to have to try to hold slight down elevator in manually when descending. . ...
Just a thought !! When I trim my models I trim for level flight at full throttle .Some people like level flight trimmed at 3/4 throttle ,which means as you throttle up you climb.... If you trim your spit as i do pulling back to 3/4 throttle will make you automatically descend which will help when you then deploy flaps.......Personally I deploy flaps at around 3/4 to 2 / 3 throttle and on down wind leg and then down to 1/2 throttle on up wind leg on final steep descend , once past the thresh hold throttle goes down as I previously explained..
