ORIGINAL: Dave Kelly
I bought the Dreamworksrc flash gear which is Bomb proof! The trunnions are wider than the standard set-up and a bit of Dremelling is required.....any questions just ask?
Dave K
Dave, did you find you had to extend the opening for the nose gear? I've just started to look at mine and it appears I'll have to remove some material from the nose wheel well as the dreamworks strut/wheel combo is a bit long. Sound normal to u?
Mike
