You deffinately have to do this. Unfortunately, you mentioned it here so you will have to accompany it with a build thread as well. Sorry, that's the rules
Check out the kit builders forums here and I am sure someone will be able to give you a resource to send the plans in to a laser cutter and get all the formers and wing ribs pre cut. This will save you countless hours and give you a nice product when you are done. I also recommend you order two coppies of the plans.
