ORIGINAL: huck1199
For your cowl molding you may want to cover the plug with some of that bad lining matterial and wb poly. Then smear some vasaline on it as a mold release before your glassing procedure. This would save having to carve out the pink foam. Some guys spray with Pam as a mold release.
Neat idea. Your suggestion to smear with some vasaline is funny. I used Lard (yep cooking LARD) just behind the fire wall so I could pop the whole affair off the fuse.
<br type="_moz" />
