RCU Forums - View Single Post - PAW 033
Thread: PAW 033
Old 10-09-2011 | 05:15 AM
AMB
Default PAW 033
It came home at last Fiery did a super job, piston and liner replaced with parts supplied by David Owen ( his card enclosed) plus a few spares acorn prop nut. rear drive washer, extra needle for carb, Fiery spent a few hours setting up and running in smooth as silk, easily started with a few hand flips, just holding in my hand a few drops down the carb of fuel
contra piston and compression screw smooth as silk, this is the one I messed up by being overhanded, bent the rod, then broke the piston trying to remove the wrist pin.
maybe an other short bench run ( really may not need it) then into a little park flyer. giving a lot of thought to the Ripmax Coyote power glider which came with a electric motor and 6 inch folding prop the 033 swings a 7x4 ,this is a easy conversion since all balsa slab side , easy new fire wall install and tons of room for a little tank the the throttle server when that big brick of a nicad battery gone martin
typo it is PAW 55
