RCU Forums - View Single Post - Programming a 3 position switch for off/on for 12Fg
Old 10-11-2011 | 08:44 AM
Bax
Default RE: Programming a 3 position switch for off/on for 12Fg
When you use a switch to be the control of a channel, you don't edit the switch positions like you do with a mix or condition. You go into the Model Menu and then the AFR section and set the curve. Use EXP1 or POINT to get the positions of the switch set the way you want them.
