Programming a 3 position switch for off/on for 12Fg
VA
I have a 12FG and I'd like to use switch SG to turn my smoke pump on/off. I have pump connected to channel 12 witch is assigned to AUX1. In the FUNCTION menu, I have the Control for AUX1 = SG and TRIM = RD to adjust the pump flow rate. However when I edit Control SG, it does not give me the option to edit ON/OFF and set the switch positions. What am I doing wrong? Thanks
Keith
Keith
When you use a switch to be the control of a channel, you don't edit the switch positions like you do with a mix or condition. You go into the Model Menu and then the AFR section and set the curve. Use EXP1 or POINT to get the positions of the switch set the way you want them.
