RCU Forums - View Single Post - Stinger 2
Thread: Stinger 2
Old 10-12-2011 | 06:31 PM
  #52
AkitoI
Default RE: Stinger 2
Glad I found this thread! I got a Stinger 2 about a month ago and I have been slowly getting it put together...been spending maybe a night a week on it.
Finally got the cowl cut out last night so i'm on the home stretch!
I have installed a Saito YS 72 in it and it was a bit of a challenge with the throttle linkage, and the motor just barely mounted with the right cowl/spinner/firewall spacing. To make the throttle linkage work I got the Dubro 4stroke kit and it worked well.
Installed Spektrum/JR DS821 Digital Servo's so I guess I won't be using the Futaba stickers in the kit!!
Anyone else setup the plane with Flaperons? I imagine with the wing shaped the way it is they won't really be needed, but I figured it would be pretty cool to play with.
Imounted the exhaust outside of the cowl, and didn't bother cutting out the bottom at all. Ihope that with the side flaresairflow will provide enough exhaust for the hot air....opinions?
Ilike the in cowl 4stroke setup that was pictured above. Anyone know if that can be done with a Saito?
