New 1/8 scale nitro buggy from HPI, the D8S.
It's an RTR version of the Hot Bodies D8, cheaper because it allows you to buy the upgrade parts later. Comes with the Nitro Star F3.5 engine and an HPI 2.4ghz radio system, Good features for an RTR, including big bore alloy shocks, helically cut gears, and dual disk brakes
http://www.hpiracing.com/kitinfo/106116/
Features Summary
* Ready to Race version of the World Champion D8 buggy
* Fitted with Nitro Star F3.5 engine
* TF-40/RF-40 2.4GHz 3-channel radio system with failsafe and drop-down steering wheel
* Powerful SB-5 steering servo
* SF-10W waterproof throttle/brake servo
* 4mm 7075 aluminum chassis with centralized weight balance
* Easy radio tray removal for maintenance and cleaning
* Composite chassis braces for extra driving feel
* Lightening cut-outs under servos, engine and clutch bell
* Tough oil-filled gear differentials
* Spiral-cut diff gears for extra durability
* Dual fiber disk brakes with easy-access adjustable linkage
* Secure forward-mounted receiver & battery box
* Unique HB solid suspension arms
* Silicone oil-filled HB Big Bore shocks with threaded aluminum bodies
* HB Inverse Steering Block Design front end
* Thick steel turnbuckles
* Total adjustability: roll center, wheelbase, camber, sway bar and more
* Top quality HB racing wheels and tires
* Aluminium shock towers have multiple shock mounting positions
* Quick access to all critical maintenance points
* Dual bellcrank steering with aluminum drag link
* Cam type servo saver
* Large fuel tank with internal baffles
* Fuel tank clunk helps engine stay running if car is upside-down
* All socket head hardware
* Full set of rubber-sealed ball bearings
