RE: sheeting foam with gorilla glue
I'm sheeting the wing cores on a Sig Mustang 450. The tips of the cores are very thin, maybe 1/4 inch and under-cambered. They will have to be in the shucks to cure. I've used white glue and epoxy with good results. I just thought I'd give the Gorilla/poly glue a try. Oh, I assume that if you have to mist it with water it is a poly glue, correct?
