In between working on the truck (plus i did some of that last night), I did some work on the 14 today...
First up, was getting that windscreen done. Sooooo...
I installed the lower side frame panels to the windscreen:
Then i made the template for trimming the left side windscreen opening on the piece of litho i made yesterday:
Then traced the template onto the litho panel, then cut that portion out:
Then i did the same for the center frame opening:
Then i flattened this out with my little roller and made a tracing of it for the other side:
Then all the screw details were hammered into the plate and attached to the windscreen:
Then the same thing was done for the other panel, and here it is completed:
Then the light frames for the vertical fins, formation light frames, and the stiffeners (the brass parts) on the sides were made up and installed on the vertical fins:
Then i made up the last 4 access panels for the vertical fins, and the last access panels for the wings. Once these are installed, All of the litho detailing will be 99% done. The only thing left to do, is the exhaust nozzle parts.
Then i glassed the exhaust nozzle plug. Once it goes green, i'll trim the glass and glass the end of the foam, then leave it to cure. Then i guess while i wait, I will either make the turkey feather panels, or finish the aft fuselage mods.
