RCU Forums - View Single Post - sheeting foam with gorilla glue
Old 10-16-2011 | 01:59 AM
jaka
Default RE: sheeting foam with gorilla glue
Hi!
Yes! And if you want thin, hard, (razor sharp) rear edges on your wing you put in some 24 hour epoxy and carbon fiber under the rear parts of the balsa sheets prior to putting the balsa sheets together.
Polyurethan glue and 24 hour epoxy cure even if they are slightly mixed.
