Well, after setting all night I pulled the first sheeted wing out of the shucks this morning. Some of the glue foamed out and stuck to the shucks, but no big deal, a little sandpaper will take care of that. The shucks were "paper" thin near the rood so basically they have been destroyed. At this point it does not make any difference. I still think this is as easy or easier than epoxy. My concern about the open time was unfounded. PLENTY of time to get it done.
dhal22.... I used a squeegee to apply the glue. I used the same technique as applying glass to the outside. If it looks wet and shiny you have too much on, if it looks dry you need a bit more.
I think I'm going to start a build thread in "Kit Building" on this. See ya there
