RCU Forums - View Single Post - KingTech K-80 message.
Old 10-18-2011 | 07:09 AM
Hanapi's Avatar
Hanapi
Default RE: KingTech K-80 message.
ORIGINAL: lov2flyrc
Pump limit will vary depending on the pump brand. Limit should be around 220-240 for Hausel brand pump. Do you have excessively long fuel lines on the test stand? Should not be getting a limit error with a 232 limit value on the test stand unless you have a restriction. If this is the flightworks pump, limit value is far too low.
Ok thanks.
Let me take a look at the brand so I know for sure.
JR
