KingTech K-80 message.
I got my kingtech K-80 back from Barry and put it on my test stand to run it.
When I throttled up to full I got a message saying "pump has reached its limit".
I can't rember ever seeing this.
Is this normal or is there something wrong?
Please let me know.
JR
Please let me know.
JR
ORIGINAL: lov2flyrc
Which pump version, Flightworks or Hausel?
What is the Pump Limit setting in the ''Run'' menu?
The pump limit was at something like 232.
I also noticed at full throttle it runs over the stipulated 145.000 rpm.
Just got mail from Chunag who told me to reduce the max rpm to 144000 and add between 2-12 to the max pump limit.
My Feedback: (24)
Pump limit will vary depending on the pump brand. Limit should be around 220-240 for Hausel brand pump. Do you have excessively long fuel lines on the test stand? Should not be getting a limit error with a 232 limit value on the test stand unless you have a restriction. If this is the flightworks pump, limit value is far too low.
ORIGINAL: lov2flyrc
Let me take a look at the brand so I know for sure.
JR
