RE: Best small scale flyer
You can merely replace the small RX that comes with the plane with one that works with your TX.
I assume you have 2.4ghz gear...
The Accucell is based upon the iMax b6 Charger design.
That charger is the basis for the Hitec, Venom, and many other chargers.
It has no problems balance charging Parkzone and Eflite packs and also doing straight charging for each.
HK also sells adapters for other dissimiliar packs such as the Thunder Pro packs, that vary in their balance lead connectors/pinouts.
