 Best small scale flyer >
Old 10-17-2011 | 06:21 PM
Default Best small scale flyer
What's a good small plane for backyards or parks that is easy to fly with 4ch and is fairly crash resistant. I already have flight experiance with the hawksky but was looking for something small and crashable just for smaller areas.
Hobbyking suggestions are preferred (USA warehouse ideally but not required) but anything is welcome!
Thanks!<br type="_moz" />
Old 10-18-2011 | 10:09 AM
bigedmustafa's Avatar
Default RE: Best small scale flyer
I've been fairly impressed with the Parkzone micro T-28 Trojan. It's available RTF or BNF, it looks good and it flies very well. It can be flown indoors in a gymnasium-sized space as well.
http://www.parkzone.com/Products/Def...rodID=PKZU1500
Old 10-18-2011 | 10:18 AM
opjose's Avatar
The Trojan is a great flying plane, but unless you have a lot of space ( e.g. ACRES of land ) in your back yard, it may be too big for many residences.
In our area flying a Trojan or almost any plane will cause the Park Police to permanently escort you out, never to return lest you face a big fine.
However our club members fly the Trojan's all the time at Fun-Fly's... they are a riot when grouped together....
I really don't see anything at HK that I would consider suitable for an area less than 1-2 acres.
For the latter you want a Slow Stik or Micro-Flyer.
Old 10-18-2011 | 10:28 AM
carrellh's Avatar
The plane in the link is not the plane in your picture
Wingspan: 16.8 in (426mm)
Overall Length: 13.5 in (343mm)
Flying Weight: 1.3 oz (38.0g)
Old 10-18-2011 | 10:39 AM
Thank you, carrellh. I did specify the micro T-28 Trojan:
[youtube]http://www.youtube.com/watch?v=pM1dfkNZltI[/youtube]
Old 10-18-2011 | 11:37 AM
opjose's Avatar
- Sorry yes, my bad! -
The Micro Trojan is a great choice for smaller areas.
I had forgotten about it.
Old 10-18-2011 | 04:47 PM
I like the micro line they have, your link got me looking around their site and I think I like the micro corsair a bit better. It says it can do slow flybys which sound great but is aerobatic too!<div><a href="http://www.parkzone.com/Products/Default.aspx?ProdID=PKZU1680">http://www.parkzone.com/Products/Def...rodID=PKZU1680
I have a turnigy accucel charger does anyone know if it is possible to charge one of those batteries with it?
A</a>fter doing a little reading it looks like all the micros require you to buy the rtf that comes with the rx and tx or have a spektrum unit to bnf. I dont have a spektrum yet.... and I don't want another tx/rx.</div>
Old 10-18-2011 | 05:55 PM
opjose's Avatar
You can merely replace the small RX that comes with the plane with one that works with your TX.
I assume you have 2.4ghz gear...
The Accucell is based upon the iMax b6 Charger design.
That charger is the basis for the Hitec, Venom, and many other chargers.
It has no problems balance charging Parkzone and Eflite packs and also doing straight charging for each.
HK also sells adapters for other dissimiliar packs such as the Thunder Pro packs, that vary in their balance lead connectors/pinouts.
Old 10-18-2011 | 06:21 PM
The description says that the ESC is a receiver/ESC combo in one unit.... That's what I was confused about.
Old 10-18-2011 | 07:55 PM
opjose's Avatar
ORIGINAL: hyrulejedi86
Actually that is correct, the AR6400 does indeed have an integrated ESC and microservos, so it must be used with a Spektrum/JR TX.
If you don't want to get a RTF setup, check out the small foamies over at BPHobbies.
