RCU Forums - View Single Post - d/R and expo question
Old 10-19-2011 | 12:04 PM
jcoop65
Default d/R and expo question
Ok so im setting up a 50cc aerobatic mx2 and would like some input and suggestions on D/R and expo settings. First off im using a DX 8, it has three rate possitions on all the control surfaces, I'd like to stick to just one swicth for all of my rate variables. In doing so I'm most comfortable with using the f mode switch, small switch on the left. What would be the best settings for the different rates? I've used expo but am not sure what is a good starting point with different rates.
On the lower rates I would want good response with easy smooth controlability. Also with the lower rates I want enough control to be able to recover if need be.
THANKS John
