RE: ASP 108
Ed, they run good when you get a good one. On my ASP .91 the carb barrel cracked from the clinch bolt. I do not think I over tightened. The metal seems very soft. Repaired it by straighting it and putting glue in the crack. Had a similar proble when tightening the trottle arm on the carb barrel of a Magnum .30 four stroke. The metal seems very brittle. The only engines I have this kind of issue are Magnum and ASP. It could be coincidence, but that is what I form my opinion on. No such problems with Fox, TT, OS (long ago), and others.
