RCU Forums - View Single Post - Hangar 9 Beast set-up
Old 10-21-2011 | 12:49 PM
rrritchey
Default RE: Hangar 9 Beast set-up
Hi,
On the servo rail there is a slot for the Ignition Cutoff control. You got a 5" jumper with male on both ends. One end of the jumper plugs into the control port. The other end can plug into either a channel coming out of the Comp 12 you have connected to your receiver or directly to your receiver.
