RCU Forums - View Single Post - Eagle Aviation One Design Build
Old 10-23-2011 | 08:41 AM
Tony Hallo
Default RE: Eagle Aviation One Design Build
Commercial cowl is not available so I must dupicate the cowl from my friends plane. This worked out well since the original cowl was already cut and my friend plans to change engines. So I need to make 2. I found the work below very interesting and decided to try this method using Ultracal 30 from US Gypsun.
I filled in the cutouts in the original cowl and use it for the plug.
www.youtube.com/user/sevarg7226#p/u/44/DkrRybDx5Y4
The results provided acceptable results at considerable time saving verses laying up a epoxy mold. Not perfect but compleetly accepable.</p>
ID:	1677835   Click image for larger version
