RCU Forums - View Single Post - O.S. 55AX dying
Old 10-23-2011 | 10:38 AM
JohnBuckner's Avatar
JohnBuckner
Default RE: O.S. 55AX dying
ORIGINAL: Avalanche2
Ive put all the screws back to Factory settings [email protected] out and [email protected] out.. its hard to get going at all but, will run wide open, as soon as I start lowering the RPMs it dies..
This is your problem those are only recommended starting positions. The high speed needle during tuning will be leaned from that setting on the first startup considerably and how much will vary on your local density altitude and temperature. The engine must be adjusted from that starting position. You are running to rich.
Get experianced help and mentoring.
John
