ORIGINAL: khkim0102
Hi, boaters!
I would like to get your opinions from your experiences and knowledge, since I am not a really experienced and knowledgeable boater. I guess I am just a little better than beginniers
Q#1. Does this motor work in the ARPRO 700 EP Brushless boat? Here is the link for the motor.
http://www.hobbypartz.com/07e-c-sl-10t-2848-blue.html
Here is the link for the boat.
http://www.nitrorcx.com/99b-10016-bl...0-ep-artr.html
Q#2. What is the diameter of the flex calve of this ARPRO boat? 3.17 mm or thicker?
Q#3. Which boat is better one? ARPRO 700 EP that I mentioned above or Sword 630 Mono 1 competetion? Here is the limk.
http://www.nitrorcx.com/99b-10018-630-ep-artr.html
If anyone can give me an asnwer, it will be greatly appreciated[8D]! Thank you very much for your attention!
I would go with the second boat listed
and for the motor, keep it stock, the one you listed is way to much kv
that little boat on 3s will run great with the stock motor
