RE: What to go with
Well since dude said he had no clue, let me help to steer you in the right direction. No 8th class is not the best. 10th scale class is. By a landslide. That settled, you have the shaft driven rigs, & the moa's. Shaftys are more prevalent because alot of folks like the tranny/driveshaft bit. But, the main reason is they're cheaper. Alot cheaper. To build anyway. The losi comp rig is pretty comp specific- a badass rig to be sure. If you want to have fun & spend less-get the ax10. Not as capable stock, but i don't ever remember seeing a stock one anyway!lolol Next are the moa's. Bergs rule here. XR10 is in the rear view tho. Be prepared to drop a grand or 2 into one of these things. & if you love crawling & comps, worth evry penny! Hope that helped some.
