RE: unhinging control surfaces
The previous two posts have the answer. The hinge must be sacrificed. use a brass or steel tube that will just slide over the hinge. Use it like a drill or hole saw to remove the half of the hinge point in the wood. Make a round plug to fill the hole and glue in. Redrill the plug for new hinge points.
