RCU Forums - View Single Post - Select engine(s) if had to replace bearins in less than a year
Old 10-31-2011 | 08:19 AM
  #110
jessiej
Default RE: Select engine(s) if had to replace bearins in less than a year
I have had no problems with bearings in these engines. (I could add many other brands to the "NN Problem" list as well.
I always use a bit of castor in the fuel, don't run too lean, and use ATF after running.
jess
